MikeSharp01 Posted November 28, 2021 Share Posted November 28, 2021 Got a load of these https://www.tlc-direct.co.uk/Manufacturers/LEDlite/Smart_WiFi_Bulbs/index.html for new house and have been experimenting - not having the success I thought I would have. Anybody know anything about these devices, and the app they come with, other than what it says on the TLC website which is frankly, to say the least, unhelpful. I have struggled all afternoon to get a bulb configured WiFi and Bluetooth - no joy. Any thoughts, other than take them all back, anyone? Link to comment Share on other sites More sharing options...
SteamyTea Posted November 28, 2021 Share Posted November 28, 2021 Just been discussing a similar thing here: Link to comment Share on other sites More sharing options...
Radian Posted December 6, 2021 Share Posted December 6, 2021 On 28/11/2021 at 17:45, MikeSharp01 said: Got a load of these https://www.tlc-direct.co.uk/Manufacturers/LEDlite/Smart_WiFi_Bulbs/index.html for new house and have been experimenting - not having the success I thought I would have. Anybody know anything about these devices, and the app they come with, other than what it says on the TLC website which is frankly, to say the least, unhelpful. I have struggled all afternoon to get a bulb configured WiFi and Bluetooth - no joy. Any thoughts, other than take them all back, anyone? Generic Tuya lamps. Use with Smart Life or Tuya app. Pairing with 2.4mHz wifi only - can be problematic. you may need to reset them to pair direct (i.e. they put up a wifi access point that you connect to initially). This usually involves power on-off-on-off-on-off-on then it flashes slowly. App has option for Easy (actually hard) or AP mode when you add a new device. Choose AP and follow instructions. Link to comment Share on other sites More sharing options...
MikeSharp01 Posted December 7, 2021 Author Share Posted December 7, 2021 16 hours ago, Radian said: Generic Tuya lamps. Use with Smart Life or Tuya app. Pairing with 2.4mHz wifi only - can be problematic. you may need to reset them to pair direct (i.e. they put up a wifi access point that you connect to initially). This usually involves power on-off-on-off-on-off-on then it flashes slowly. App has option for Easy (actually hard) or AP mode when you add a new device. Choose AP and follow instructions. Many thanks for that - I found that out of the box I could get them connected but those I had tried would not work - so now I have the on-off-on-off-on-off-on sequence I can probably get them back to slow flashing as out of the box. Link to comment Share on other sites More sharing options...
John Lewis Posted December 2, 2022 Share Posted December 2, 2022 On 28/11/2021 at 20:45, MikeSharp01 said: Got a load of these https://www.tlc-direct.co.uk/Manufacturers/LEDlite/Smart_WiFi_Bulbs/index.html for new house and have been experimenting - not having the success I thought I would have. Anybody know anything about these devices, and the app they come with, other than what it says on the TLC website which is frankly, to say the least, unhelpful. I have struggled all afternoon to get a bulb configured WiFi and Bluetooth - no joy. Any thoughts, other than take them all back, anyone? I have had experience with TLC Smart WiFi Lamps. I have not had any problems with them. Your problem is that you may not have connected them correctly. Link to comment Share on other sites More sharing options...
