Adsibob Posted November 21, 2021 Posted November 21, 2021 I have two Velux integra. They each come with a remote control. I don’t like the idea of these being remote controlled, because we will lose the remotes. I also don’t want to just stick it on the wall, because the wall space is tight and they will clash with the nice light switch plates we are getting. Is it possible to add a module to my light switch plate, converting, say , a one gang to a two gang rocker in one case and turning a three gang to a four gang in the other case, and then wire up that module to control the Velux? How would I go about doing this? Is it basic DIY, or do I need an electrician? (My electrics DIY extend to changing a light switch, but not much further beyond that.)
ProDave Posted November 21, 2021 Posted November 21, 2021 Can you post a picture or link to the existing remote control to get an idea what you are trying to replicate? Withou knowing or seeing it, I would guess there are two pushbuttones one for open and one for close? And a link to the type of posh light switches you are going to have?
Adsibob Posted November 21, 2021 Author Posted November 21, 2021 1 minute ago, ProDave said: Can you post a picture or link to the existing remote control to get an idea what you are trying to replicate? Withou knowing or seeing it, I would guess there are two pushbuttones one for open and one for close? And a link to the type of posh light switches you are going to have? I believe the integra switch is like this: https://www.sterlingbuild.co.uk/product/velux-kli-311-wall-switch-for-integra-roof-windows?gclid=Cj0KCQiA-eeMBhCpARIsAAZfxZBCTQcafAHcplN7MKgvfwbKAcx0-wtHnosm0oRqnsh_3HxJzcTs_moaAnpdEALw_wcB&gclsrc=aw.ds as for the light switches, I wanted to get Corston, but even with my architect’s 20% discount, I don’t think I can afford them, so just something standard witha matt black or metallic finish like this: https://www.se.com/uk/en/product-range/60837-ultimate/?parent-subcategory-id=5620
ProDave Posted November 21, 2021 Posted November 21, 2021 No obvious solution. About all I can suggest if your engineering skills are up to it, is buy the Velux wall switch, and a blank plate of your chosen switch type, drill a large hole to match the round cluster of buttons on the velux switch to make a front cover to match your other switches. If not engineered well it could just look rubbish.
Adsibob Posted November 21, 2021 Author Posted November 21, 2021 Thanks. SWMBO has just pointed out that there is a cupboard in the landing where we can mount one of these, and as for the other I will just have to not lose it.
