Moggaman Posted November 19, 2021 Posted November 19, 2021 Hi . I have 150mm of insulation to go on my sub floor before screed. I hear some people say that it is best to cross the insulation as in lay 50mm one way and 100mm the other way..staggering the joints. I presume that this is best because the first lay of 50mm can be laid adjacent to first fix plumbing pipes and then the 100mm laid over at a different angle.. thing is.. I have some rooms with no first fix water pipes in them, so I could just lay the 150mm boards in one hit in these sections. Is there any issue with this? thanks
Marvin Posted November 19, 2021 Posted November 19, 2021 Nothing wrong with 150mm in one go. If you have 2 layers it's thought a good thing to stagger the joints, a bit like 2 layers of plasterboard or loft insulation.
Russell griffiths Posted November 20, 2021 Posted November 20, 2021 I did two layers for a few reasons. To stagger joints 150mm is a bit stiff and if your floor has any undulations I found the thinner layers conforms to this better. 150mm is a pain to cut as it grips the saw, thinner sheets easier to cut.
Moggaman Posted November 21, 2021 Author Posted November 21, 2021 On 20/11/2021 at 14:02, Russell griffiths said: I did two layers for a few reasons. To stagger joints 150mm is a bit stiff and if your floor has any undulations I found the thinner layers conforms to this better. 150mm is a pain to cut as it grips the saw, thinner sheets easier to cut. Thanks
