The design of our warm roof has 100mm insulation between the vapour barrier and the steel coating and an additional 70mm underneath between the wooden spars. There is a suspended ceiling below all of this.
Is it better to insulate above the suspended ceiling than to put the 70mm insulation between the spars?
The reason to ask is that I am concerned that the heat will just go through the suspended ceiling and into the unused loft space.
A drawing would help. Be aware that having the insulation at rafter level but with a horizontal ceiling has a major negative impact on the calculated U-value. You may think you are getting say 0.18 W/m2K but due to the correction factor it may be nearer perhaps 0.22 W/m2K!
A warm roof is insulated at rafter level (like mine), yes the volume of the house is larger so will affect the overall u value but I wanted a usable loft storage space and find it works fine as long as your insulation is adequate.
