Leaking shower glass
26 minutes ago, LeakySeal said:
Thanks, is this normal with these types of glasses?
Is what normal? Are you saying you have water running under the screen and onto the floor? If so then it’s the bath at fault and not the screen.
Assuming the screen is hinged to aid access, do you really want to silicone it?  Maybe it's fixed a bit too far out?  If it was moved back towards the taps a bit, would that help direct the run-off back into the bath rather than over the side?
If hinged as above wouldn’t add silicone, some form of silicone trim slid on to the glass is usually the normal.
Regards. James
