Arnold9801 Posted October 24, 2021 Posted October 24, 2021 I'm going to be fitting 10mm fascia boards on to 18mm ply tomorrow. What's the best spacing to aim for with the plastic capped nails? I was thinking of 2ft or is 3ft/1m best? Advice would be appreciated. Arnold9801
tonyshouse Posted October 24, 2021 Posted October 24, 2021 I wouldn’t use ply ?. 600mm c/c ss capped pins look nicer than nails, gutter brackets can help too
Arnold9801 Posted October 25, 2021 Author Posted October 25, 2021 Thank you for your replies. Arnold9801
Conor Posted October 25, 2021 Posted October 25, 2021 Ply will swell and warp. I used 12mm OSB. Cheaper and a better job. We screwed at 200mm centres and a bead of adhesive. but that was render board which is much heavier.
