epsilonGreedy Posted September 27, 2021 Posted September 27, 2021 I have discovered the utility value of bar clamps in recent weeks while fitting fascias, so I am going to buy a few more. The two Eurbauers I have been using came bundled with track saw and are budget models I assume. So off the Screwfix for a few extra clamps and I am confused that Irwin offer three models of a 6" clamp with a 3x price range. Apart from the larger jaws on the £20 model what else justifies the price difference? £6 https://www.screwfix.com/p/irwin-quick-grip-mini-bar-clamp-6/29139 £12 https://www.screwfix.com/p/irwin-quick-grip-bar-clamp-spreader-6/48687 £20 https://www.screwfix.com/p/irwin-quick-grip-xp-bar-clamp-6/99973#product_additional_details_container
Moonshine Posted September 27, 2021 Posted September 27, 2021 The £6 one is a clamp only and the £12 is also a spreader, which you flip one of the jaws round. The £6 one has a fixed pin in it that doesn't allow the jaw to be flipped. I guess the £20 one is just a more robust version of the £6 one. 1
saveasteading Posted September 27, 2021 Posted September 27, 2021 38 minutes ago, Moonshine said: which you flip one of the jaws round. Or both jaws? I bought some cheap ones at Aldi (or Lidl), and they are ok as clamps but a right fiddle as pushers., and awkward to adapt.
markc Posted September 27, 2021 Posted September 27, 2021 Cheap one does not have swivel jaws and they are very small and weak, £12 ones are much better. Larger one is a completely different animal. I quite like the £12 ones when kitchen fitting etc. 1
epsilonGreedy Posted September 27, 2021 Author Posted September 27, 2021 44 minutes ago, Moonshine said: The £6 one is a clamp only and the £12 is also a spreader, which you flip one of the jaws round. The £6 one has a fixed pin in it that doesn't allow the jaw to be flipped. Oh so these things can be used in spreader mode. I cannot imagine when that need would arise given my limited DIY plans post house build completion. I do intend to make many internal Victorian style window shutters after moving into the new build as these are hideously expensive when custom made.
markc Posted September 27, 2021 Posted September 27, 2021 I have around 30 clamps from 6in to 48 inch and havent used one for spreading yet.
epsilonGreedy Posted September 27, 2021 Author Posted September 27, 2021 1 minute ago, markc said: I have around 30 clamps from 6in to 48 inch and havent used one for spreading yet. After posting I was thinking could a pair be used with one clamping and the other spreading in opposition to hold something aligned against a single anchor point?
markc Posted September 27, 2021 Posted September 27, 2021 11 minutes ago, epsilonGreedy said: After posting I was thinking could a pair be used with one clamping and the other spreading in opposition to hold something aligned against a single anchor point? Yes, but the 6inch ones are overall length so only clamp around 3in between the jaws
