Velux vent bar
richie9648
I’ve realised on one of my velux installs I’ve not engaged the lock properly and that is failing to close properly. It’s an electronic integra window operated by remote control.
I understand the lock should be at the top not at the bottom as I’ve got in the picture. Is there a way of repositioning this in situ (so I don’t have to take the window down). I have tried a bit of brute force with no impact !!
It should be ok - just ensure that you hold the window when you release the chain as it will swing open / shut.
I would hold the window, release the chain, operate the bar, then reconnect the chain and try it.
How did you get it into that position? the chain releases the lock before opening the window in normal operation.
