GaryM Posted September 3, 2021 Posted September 3, 2021 The plaster and decorator have sprayed plaster and some emulsion on the radiator 10mm Hep2O pipe, before I have fitted the radiators. So what is the best way to clean the pipes so push fittings work? Thanks
GaryM Posted September 3, 2021 Author Posted September 3, 2021 22 minutes ago, tonyshouse said: Very hot soapy water for me I give it a go. it's plaster and emulsion so hot water should work it. Thanks
joe90 Posted September 3, 2021 Posted September 3, 2021 It’s scratching that you have to be careful off as this can lead to leaks around the rubber O rings. 2
Nickfromwales Posted September 3, 2021 Posted September 3, 2021 2 hours ago, joe90 said: It’s scratching that you have to be careful off as this can lead to leaks around the rubber O rings. Yup. Twisting action rather than linear strokes etc to avoid such damage. 1
GaryM Posted September 4, 2021 Author Posted September 4, 2021 yes hot soapy water did the job. Mind you it's doesn't solve drilling through a pipe... idiot ? 1
