Conor Posted August 31, 2021 Posted August 31, 2021 (edited) My GSE instructions say I need to ground the panels behind the trays. My Solar Edge instructions make no mention of earthing/ grounding. Thoughts? Edited August 31, 2021 by Conor
Marvin Posted August 31, 2021 Posted August 31, 2021 (edited) and because I have panels on a metal frame this is the reason I have to earth bond the frame.? Edited August 31, 2021 by Marvin Clarification, hopefully.
willbish Posted August 31, 2021 Posted August 31, 2021 4 hours ago, Conor said: Seems no: Agreed Jinko Panels on GSE trays, no earth bonding. Sparky happy
offthepiste Posted February 18, 2022 Posted February 18, 2022 Useful info ... looking to install Sunpower Maxeon 5 AC (fitted expanse micro inverters) in two separate strings on two separate flat roofs. Came across this reasonably current Sunpower 'Safety and Installation Instructions for AC modules' dated 2021which I assume may apply to UK installs. https://sunpower.maxeon.com/uk/sites/default/files/2021-06/Safety and Installation Instructions for AC Modules 537620 RevD Final.pdf Seems to have pretty clear advice on grounding / earthing. Only question I have is whether I need to ground with separate, say copper, cable to a grounding plate / pole buried in the earth or whether I am over thinking this. Advice gratefully accepted! Cheers to all
