GrantMcscott Posted August 29, 2021 Posted August 29, 2021 Hi old joiner (if you can call him that). Has use normal nail in joist hanger and they are starting to com loose and floor making a noise. Any issue in taking them out and replacing them with twisted 30 x 3.75. Will I get the same strength as a whole is already there?
nod Posted August 29, 2021 Posted August 29, 2021 (edited) If he’s just used a clout nail Then the twist nail will be a thicker gauge Whilst not ideal They should hold Ps Shocking mistake for a joiner to make Edited August 29, 2021 by nod 1
GrantMcscott Posted August 29, 2021 Author Posted August 29, 2021 (edited) 30 minutes ago, nod said: If he’s just used a clout nail Then the twist nail will be a thicker gauge Whilst not ideal They should hold Ps Shocking mistake for a joiner to make Would putting a bit of glue in the hole help? This is the easiest mistake to fix he has made on my house build pure cowboy. Cut all the rafter doublers in the roof and lots more issues. Edited August 29, 2021 by GrantMcscott
tonyshouse Posted August 30, 2021 Posted August 30, 2021 Nail puller and replace every other one glue won’t help, might need noggins to tighten everything up in line with the trimmers 1
nod Posted August 30, 2021 Posted August 30, 2021 7 hours ago, GrantMcscott said: Would putting a bit of glue in the hole help? This is the easiest mistake to fix he has made on my house build pure cowboy. Cut all the rafter doublers in the roof and lots more issues. No Glue won’t help Replace them all with twist nails 1
