Dale Posted August 22, 2021 Posted August 22, 2021 (edited) I've run mdpe water pipe across front of property to an internal plant room, in one complete length. But wanting to tee off to fit an outside tap before the internal stop tap. Question: can I tee into the supply pipe and spur off before the internal stop tap. Or does the supply pipe have to run in to the property in an uninterrupted length? Thank you Edited August 22, 2021 by Dale
markc Posted August 23, 2021 Posted August 23, 2021 (edited) I don’t know of anything saying you can’t tee off before the main property …unless you were going before a meter. Edited August 23, 2021 by markc 1
Russell griffiths Posted August 23, 2021 Posted August 23, 2021 Why not, I have two outside taps coming off before it enters the house. 1
Gone West Posted August 23, 2021 Posted August 23, 2021 10 hours ago, Dale said: I've run mdpe water pipe across front of property to an internal plant room, in one complete length. But wanting to tee off to fit an outside tap before the internal stop tap. Question: can I tee into the supply pipe and spur off before the internal stop tap. Or does the supply pipe have to run in to the property in an uninterrupted length? Thank you I did that at our last new build and it wasn't a problem. 1
