LSB Posted August 19, 2021 Posted August 19, 2021 Hello After demolishing the top of some block walls as they were not in a good state we are building the wall back up. This needs to be on a slope to allow for the roof. This is a rough diagram to show. What we need to know is: Where the above shows mortar, is this what we use or should we be using concrete. The part blocks are cut to approx the right shape and we will put sides where the area is too small. This is how far we have got, not mortared in yet. The roof line is as per the string. TIA Jill
Brickie Posted August 20, 2021 Posted August 20, 2021 It would better to pitch the roof first,and then do the cuts to suit. 1
LSB Posted August 20, 2021 Author Posted August 20, 2021 1 hour ago, Brickie said: It would better to pitch the roof first,and then do the cuts to suit. sorry, I don't understand what you mean, could you expand. thanks
Declan52 Posted August 20, 2021 Posted August 20, 2021 1 hour ago, LSB said: sorry, I don't understand what you mean, could you expand. thanks Put the rafters on first then this will give you a better guide to fill in the small sections. 1
LSB Posted August 20, 2021 Author Posted August 20, 2021 20 minutes ago, Declan52 said: Put the rafters on first then this will give you a better guide to fill in the small sections. Thanks, we are waiting on the SE calculations on these, but that's probably a good idea.
