WWilts Posted August 17, 2021 Posted August 17, 2021 Experienced groundworks subbie proposes water main entry point. (pics of ground floor, first floor, and both approx superimposed) Barrier pipe required if going under permeable driveway. Where would you put the entry point? My instinct was nearer the existing standpipe.
Marvin Posted August 17, 2021 Posted August 17, 2021 Entrance lobby WC? Pipes have to come down anyway.... M 1
Marvin Posted August 17, 2021 Posted August 17, 2021 Don't know your situation so... You may need a water softener. You can check with your local water supplier what hardness your water supply is. If you need a water softener you may need to consider where it will go and how the plumbing would work including the non softened water to any outside tap. Good luck M 1
WWilts Posted August 17, 2021 Author Posted August 17, 2021 Does underslab water main still need to be 750mm deep?
TonyT Posted August 18, 2021 Posted August 18, 2021 Under the kitchen sink, more room to add stopcock, change from underground pipe to copper/plastic. Easy to get a main bond to it, there is a requirement for water at the sink anyway so makes sense, of course if you had plant room it would be there, even an attached garage I would consider it in there, just to keep access to the stopcock easy. 1
WWilts Posted August 18, 2021 Author Posted August 18, 2021 6 hours ago, dpmiller said: where will the outside tap be? Near kitchen
WWilts Posted August 18, 2021 Author Posted August 18, 2021 (edited) 5 hours ago, TonyT said: Under the kitchen sink, more room to add stopcock, change from underground pipe to copper/plastic. Easy to get a main bond to it, there is a requirement for water at the sink anyway so makes sense, of course if you had plant room it would be there, even an attached garage I would consider it in there, just to keep access to the stopcock easy. Thanks. Trench fill poured today, under the kitchen sink it is for the water mains entry. Hopefully will be able to run pipes (probably plastic) up and along the steel beam to supply the rest of the house. Including plumbing manifolds on (probably) upstairs landing recess, and boiler / cylinder in upstairs master en suite. That's bottom right in the first floor plan. Don't relish many holes in the ordinary timber joists Edited August 18, 2021 by WWilts
