Souljim Posted July 27, 2021 Posted July 27, 2021 Hi all, I’m taking down an old conservatory and extending it out to create a larger single storey extension. I’ve got some 25mm x 600mm steel bar to tie the new footings into the existing foundations and had a few questions. What size drill bit do I need? Is 26mm okay or do I need it to be slightly bigger (say 28mm) for the epoxy resin. I don’t want to buy an expensive resin gun to use it once either and I know you can buy some epoxy resins in a syringe that pre-mixes it. Any idea on which one’s best? Thanks
PeterW Posted July 27, 2021 Posted July 27, 2021 Is this a requirement from building control ..? 25mm rebar is a little …. Extreme ..?? Should be able to use 12mm tbh as it’s only there for tension and differential movement that rarely happens.
Tom Posted July 28, 2021 Posted July 28, 2021 I've just used 16mm rebar for our footings, 18mm hole for the resin. All 200 of them.
markc Posted July 28, 2021 Posted July 28, 2021 10 hours ago, Souljim said: Hi all, I’m taking down an old conservatory and extending it out to create a larger single storey extension. I’ve got some 25mm x 600mm steel bar to tie the new footings into the existing foundations and had a few questions. What size drill bit do I need? Is 26mm okay or do I need it to be slightly bigger (say 28mm) for the epoxy resin. I don’t want to buy an expensive resin gun to use it once either and I know you can buy some epoxy resins in a syringe that pre-mixes it. Any idea on which one’s best? Thanks Morning, Sounds like you are talking about shear connectors to keep the two slabs aligned. Assuming this is the case, drill a couple of mm oversize and resin in, then slid a piece of plastic tube over the other end before the pour to allow movement. But 25mm is still a very big bar.
markc Posted July 28, 2021 Posted July 28, 2021 Oh and you dont need a resin gun, plastic or glass capsules, point of end of bar and spin in with a drill
