shbrooks Posted July 27, 2021 Posted July 27, 2021 Hi all. I've laid a fairly deep subbase, say 200mm in 50mm layers, on top of a non woven geotextile membrane down the side of our house between my neighbour and I, and plan to lay porcelain tiles on top in the future. For the time being I wanted to make the area safe as the area had been partially excavated when we had our fence replaced due to our side being 500mm higher than our neighbours (we had to previously excavate a footwide trench to remove the old posts/gravel boards). I plan to take up the rest of our patio which links round, and lay a new subbase for this in the future (existing slabs currently laid on clay ?) I have a few queries having not laid a patio before. Is the compacted subbase a suitable temporary finish or will it degrade over time?..if so, how long can you leave it before adding the tiles on top? Do I need a weed membrane on top of the subbase? I can't imagine weeds will grow between the subbase and the tiles, but would like to know if this does often happen. Do I need to introduce movement joints into the subbase, and/or tiles? Can I lay the subbase in sections? We're altering the house in the future, which will create a larger patio area but I can't lay the subbase for this until we begin the alteration works. If it is possible to lay the subbase is sections, is there anything I need to do to teeth the different sections together? Thanks for reading!
Dave Jones Posted July 27, 2021 Posted July 27, 2021 should be fine with a final level and wacker before laying. Use a strong mix sharp sand full bed under the tiles.
Brickie Posted July 27, 2021 Posted July 27, 2021 https://www.pavingexpert.com/ I believe many on here have recommended this site in the past.
shbrooks Posted July 28, 2021 Author Posted July 28, 2021 Thank you that link was helpful, although it didn't address any of the queries I have currently have, which I can't seem to find answers to.
tonyshouse Posted July 28, 2021 Posted July 28, 2021 No membrane on top, I would do a layer of reinforced concrete to help stop tiles cracking, yes definitely have movement joints
Ferdinand Posted July 28, 2021 Posted July 28, 2021 On Q2, I think it depends what you are laying your tiles on, and what your subbase is made of. If there is mortar under the tiles then probably OK, or if you are pointing between them. Remember that motar or concrete may react porcelain or stain it. Check that. If you lay on sand over the subbase with no pointing then stuff will grow eventually, yes. Also possibly ants will nest, if it matters. Or perhaps the dynamic will be different if you lay it more loosely on small gravel, as on the continent. Paving expert has several pages about it. https://www.pavingexpert.com/porcelain_03 (TBH if this is your first patio, then I would check the Wickes good idea publication, and also read the entire paving expert website about everything just for background purposes). One thing to think about is how are you managing the edge near your fence to protect the fence, and for maintenance of the fence (no contact panels to ground, think about replacing posts). F
