Marty4000 Posted July 10, 2021 Posted July 10, 2021 Hi All, I am in the planning stage of a project for a single storey extension and I am sorted with most things. However, I am stuck with the roof pitch, I need a minimum of 15 degree for the tiles I want to use. I am looking at 3 meters at ridge height and possibly 2.4 or 2.3 meters at eaves height, my question is what would be the pitch of these options. Thanks in advance
ProDave Posted July 10, 2021 Posted July 10, 2021 I have hidden your duplicate threads, no point asking in more than one place. Someone will be along soon I am sure to do the trigonometry.
A_L Posted July 10, 2021 Posted July 10, 2021 3 hours ago, Marty4000 said: However, I am stuck with the roof pitch, I need a minimum of 15 degree for the tiles I want to use. I am looking at 3 meters at ridge height and possibly 2.4 or 2.3 meters at eaves height, my question is what would be the pitch of these options. Not enough info. The vertical difference/horizontal difference must be 0.27 or greater for at least 15°
Marty4000 Posted July 10, 2021 Author Posted July 10, 2021 6 hours ago, A_L said: Not enough info. The vertical difference/horizontal difference must be 0.27 or greater for at least 15° What further info do you require? Does this help, the roof area is 4 meters width by 4 meters length
A_L Posted July 11, 2021 Posted July 11, 2021 10 hours ago, Marty4000 said: Does this help, the roof area is 4 meters width by 4 meters length If this is the usual two pitched roof with the ridge in the middle then the ridge needs to be at least 2 * 0.27m or 0.54m above the eaves. If it is a single pitch roof then one side has to be at least 0.27 * 4m or 1.08m above the opposite side.
Marty4000 Posted July 11, 2021 Author Posted July 11, 2021 25 minutes ago, A_L said: If this is the usual two pitched roof with the ridge in the middle then the ridge needs to be at least 2 * 0.27m or 0.54m above the eaves. If it is a single pitch roof then one side has to be at least 0.27 * 4m or 1.08m above the opposite side. Thanks A_L just what I was after
