Hi All,
I am in the planning stage of a project for a single storey extension and I am sorted with most things.
However, I am stuck with the roof pitch, I need a minimum of 15 degree for the tiles I want to use.
I am looking at 3 meters at ridge height and possibly 2.4 or 2.3 meters at eaves height, my question is what would be the pitch of these options.
Thanks in advance
I have hidden your duplicate threads, no point asking in more than one place.
Someone will be along soon I am sure to do the trigonometry.
Not enough info.
The vertical difference/horizontal difference must be 0.27 or greater for at least 15°
6 hours ago, A_L said:
Not enough info.
What further info do you require?
Does this help, the roof area is 4 meters width by 4 meters length
If this is the usual two pitched roof with the ridge in the middle then the ridge needs to be at least 2 * 0.27m or 0.54m above the eaves.
If it is a single pitch roof then one side has to be at least 0.27 * 4m or 1.08m above the opposite side.
Thanks A_L just what I was after
