Roof pitch of extension
Hi All,
I am in the planning stage of a project for a single storey extension and I am sorted with most things.
However, I am stuck with the roof pitch, I need a minimum of 15 degree for the tiles I want to use.
I am looking at 3 meters at ridge height and possibly 2.4 or 2.3 meters at eaves height, my question is what would be the pitch of these options.
Thanks in advance
Not enough info.
The vertical difference/horizontal difference must be 0.27 or greater for at least 15°
6 hours ago, A_L said:
Not enough info.
What further info do you require?
Does this help, the roof area is 4 meters width by 4 meters length
If this is the usual two pitched roof with the ridge in the middle then the ridge needs to be at least 2 * 0.27m or 0.54m above the eaves.
If it is a single pitch roof then one side has to be at least 0.27 * 4m or 1.08m above the opposite side.
Thanks A_L just what I was after
