Greetings. I had some Wunda UFH pipe (I believe it's Pert-al-pert) delivered on 10th May and I've left them outside since then as I decided not to use them for the basement. Anyone know if the exposure to UV would've compromised the pipe at all or should it be still ok?
  • 1 month later...
36 minutes ago, RHayes said:
There is a good chance that the UV exposure will have degraded the oxygen barrier in the pipe.
thanks for the response. I thought that might be the case. I will double check with Wunda what the maximum UV exposure time is. it's still wrapped in their paper type packaging which might help I guess.
Yes, that is likely to have prevented it.  I know we wrap our pipe in black wrap to prevent UV exposure and are able to store this outside for this reason.
I moved it all to the garage quite a few weeks ago as well so it's now in the dark. hopefully it'll be ok.
Just now, dpmiller said:
what exactly does UV do to aluminium please?
Nothing! Atmosphere will cause oxidation and UV can fade paint but Alu itself isn’t affected.
Valid point.  Apologies I overlooked the fact that the barier is the aluminium.  Apologies for the misinformation.
