MortarThePoint Posted June 28, 2021 Posted June 28, 2021 (edited) British-Gypsum and GTEC resilient bars are about twice the price of lesser brands like Tradeline/Libra/Speedline/Phoenix. thickness and dimensions seem the same, so is that just the price of branding at play. I should imagine its all the same isn't it? I prefer the look of bars that have the acoustic holes away from the fold, but given the fact that both premium (BG) and budget (Libra) have holes on folds it doesn't seem an issue. Knauf double up and do both. SpeedLine: TradeLine(secondary source? Siniat GTEC: Gypframe: Knauf: Edited June 28, 2021 by MortarThePoint
nod Posted June 28, 2021 Posted June 28, 2021 Yep All the time Some of our jobs spec BG The ones that don’t We use tradeline Or Gtec About a third cheaper 1
MortarThePoint Posted June 28, 2021 Author Posted June 28, 2021 1 hour ago, nod said: Yep All the time Some of our jobs spec BG The ones that don’t We use tradeline Or Gtec About a third cheaper I like the look of the Tradeline ones
nod Posted June 28, 2021 Posted June 28, 2021 1 hour ago, MortarThePoint said: I like the look of the Tradeline ones yes there just a thinner gauge of metal than BG
MortarThePoint Posted June 28, 2021 Author Posted June 28, 2021 (edited) 14 minutes ago, nod said: 1 hour ago, MortarThePoint said: yes there just a thinner gauge of metal than BG On paper it's the other way round. TradeLine claim 0.5mm gauge and BG claim 0.45mm. Probably the joys of tolerances at play though which means the TradeLine is the thinner as you say. <rant>'Tolerances' is one of the great deceptions of the construction sector as far as I am concerned. Most other lines of work the nominal is what the manufacturer tries to achieve so sits in the middle of the distribution (mean) and the tolerance sets the width of the tails either side. In construction supplies, many seem to treat it that as long as X% are within nominal +/- the tolerance, they can reduce the mean to save money. Hence 100mm blocks actually being 96mm etc. It's a con in my eyes.</rant> British Gypsum: TradeLine: Edited June 28, 2021 by MortarThePoint 1
MortarThePoint Posted June 28, 2021 Author Posted June 28, 2021 Ordered the TradeLine one at £2.35 per 3m length which is cheaper than 100x22 timber
nod Posted June 28, 2021 Posted June 28, 2021 3 hours ago, MortarThePoint said: On paper it's the other way round. TradeLine claim 0.5mm gauge and BG claim 0.45mm. Probably the joys of tolerances at play though which means the TradeLine is the thinner as you say. <rant>'Tolerances' is one of the great deceptions of the construction sector as far as I am concerned. Most other lines of work the nominal is what the manufacturer tries to achieve so sits in the middle of the distribution (mean) and the tolerance sets the width of the tails either side. In construction supplies, many seem to treat it that as long as X% are within nominal +/- the tolerance, they can reduce the mean to save money. Hence 100mm blocks actually being 96mm etc. It's a con in my eyes.</rant> British Gypsum: TradeLine: I was referring to there MF in general Quite flimsy compared to BG But does the same job once boarded We never stand studs up and leave them un boarded Where as BG we often stand a couple of hundred metres of studs up before we board You get what you pay for 1
GrantMcscott Posted July 15, 2021 Posted July 15, 2021 On 28/06/2021 at 14:40, MortarThePoint said: Ordered the TradeLine one at £2.35 per 3m length which is cheaper than 100x22 timber Hi Where did you get it for that price as I am being quoted £1.79 per m (£5.37 per length) thanks
MortarThePoint Posted July 15, 2021 Author Posted July 15, 2021 2 minutes ago, GrantMcscott said: Hi Where did you get it for that price as I am being quoted £1.79 per m (£5.37 per length) thanks Have a look at abcdepot, but I got it from Travis Perkins
GrantMcscott Posted July 15, 2021 Posted July 15, 2021 2 minutes ago, MortarThePoint said: Have a look at abcdepot, but I got it from Travis Perkins that was CCF that quoted which is part of Travis Perkins
MortarThePoint Posted July 15, 2021 Author Posted July 15, 2021 This is Libra: https://www.abcdepot.co.uk/libra-resilient-bar-3000mm.html I bought 100 lengths so that may have helped.
GrantMcscott Posted July 15, 2021 Posted July 15, 2021 27 minutes ago, MortarThePoint said: This is Libra: https://www.abcdepot.co.uk/libra-resilient-bar-3000mm.html I bought 100 lengths so that may have helped. Yes I want 89 length just a bit difference in price you at 78p and I am £2.35
