Water Posted June 6, 2021 Share Posted June 6, 2021 (edited) Hi all, I need a bit of help knowing how best to do this. I had a new electricity connection for my new build, it was routed underground but pops out of the ground by the external wall and about 1 foot above ground level goes through a hole in the wall into the house. With all the regulations around electricity I was surprised about this, are there any minimum requirements? I was trying to research it online but not coming up with anything. Thank you Edited June 6, 2021 by Water Link to comment Share on other sites More sharing options...
Temp Posted June 6, 2021 Share Posted June 6, 2021 (edited) Normally they require you to install a meter box on an outside wall and bring the connection up into that. If the cable runs up the outside of the wall it might need covering/protecting but I think that may only be necessary where there is a risk of a car impacting it? I'm not 100% sure about that though. You can get plastic covers to stop rain getting in through the hole but I've just had one crumble on me due to uv exposure. Edited June 6, 2021 by Temp 1 Link to comment Share on other sites More sharing options...
TonyT Posted June 6, 2021 Share Posted June 6, 2021 Best check what the DNO for your area say regarding the meter, meterbox, hockey stick duct etc. 1 Link to comment Share on other sites More sharing options...
Water Posted June 6, 2021 Author Share Posted June 6, 2021 (edited) Thanks, I’ve emailed them to see what they say. A car could easily clip it, well my car. Edited June 6, 2021 by Water Link to comment Share on other sites More sharing options...
