Edders Posted May 18, 2021 Posted May 18, 2021 I'm updating my heating system. Likely to replace it with a condensing gas boiler. Don't have any thermostatic valves. Any suggestions for a system that I can control each room rad stat? and HW. The proviso is that it doesn't rely on XXYY company keeping their servers on for you or that allow open source , documented control protocols that can be controlled by an open source or self-hosted control system?
MikeSharp01 Posted May 18, 2021 Posted May 18, 2021 17 minutes ago, Edders said: The proviso is that it doesn't rely on XXYY company keeping their servers on for you or that allow open source , documented control protocols that can be controlled by an open source or self-hosted control system? So are you saying NO to open source anything AND central connection anything.
SteamyTea Posted May 18, 2021 Posted May 18, 2021 Lighting Heating Timer Audio (multi room if batteries fitted) Life is sorted.
Edders Posted May 18, 2021 Author Posted May 18, 2021 hahah - that's more or less what I have at the moment !
SteamyTea Posted May 19, 2021 Posted May 19, 2021 7 hours ago, Edders said: hahah - that's more or less what I have at the moment ! Does it work
Edders Posted May 23, 2021 Author Posted May 23, 2021 Yes - Its on a timer. I can override it. I'd like to be able to control it from Home Assistant (or OpenHab) I've already setup Home Assistant (https://www.home-assistant.io) on my own hardware.
Edders Posted May 23, 2021 Author Posted May 23, 2021 Right I've answered my own question. Drayton Wiser and Tado offer an API so that external programs can interact with it. From what I've read Tado allows your program of choice to communicate with it, whereas the Drayton Wise (or Schneider Electric) allows your program to communication with the hub itself. Very useful if the provider pulls the plug on the serve. Looks like I'm going Wiser ... Relevant resources for those that want to pursue this as well HomeAssistant https://community.home-assistant.io/t/drayton-wiser-home-assistant-integration/80965 asantaga/wiserHomeAssistantPlatform DrJohnT/HomeAssistantPublicConfig OpenHab https://community.openhab.org/t/drayton-wiser-thermostat-binding/35640/405
Andehh Posted May 24, 2021 Posted May 24, 2021 Thanks very much, any continued feedback would be much appreciated as well. Having used EvoHome before and liked the concept, I am keen to explore taking thing a step further.
Pocster Posted May 24, 2021 Posted May 24, 2021 Geniushub No central server . Had it for years in 3 properties- works good
SteamyTea Posted May 24, 2021 Posted May 24, 2021 2 hours ago, pocster said: Geniushub You have had pornhub even longer.
Edders Posted May 26, 2021 Author Posted May 26, 2021 On 24/05/2021 at 18:09, pocster said: Geniushub No central server . Had it for years in 3 properties- works good Not one I've come across, I'll check it out. Thanks.
Pocster Posted May 26, 2021 Posted May 26, 2021 58 minutes ago, Edders said: Not one I've come across, I'll check it out. Thanks. Yep The hub is independent of the internet . You do need internet access to control it ( runs headless ) . So if internet fails it still works . Have it in 3 HMO’s - it survives there so should be fine in your own home
