Ryan Bazeley Posted May 17, 2021 Posted May 17, 2021 I was going going to fix 12.5mm Knauf Exterior Aquapanel to my SIPS via 25mm x 50mm battens, reading the specification information from Knauf they insist on a minimum 60mm fixing face? Does anyone who has done this know if I should fit bigger battens or will it be okay? TIA
Ryan Bazeley Posted May 17, 2021 Author Posted May 17, 2021 Thanks, I suppose it doesn’t hurt to double up if needed?
Mr Punter Posted May 17, 2021 Posted May 17, 2021 46 minutes ago, Ryan Bazeley said: Thanks, I suppose it doesn’t hurt to double up if needed? Best to use the same batten where the boards join.
Dudda Posted May 17, 2021 Posted May 17, 2021 I'd be ok with the 50mm too if you're neat but is the 25mm a bit light? It will have a fair amount of screws in it. Screws fixing the batten to the structure and then the panel to the batten which are doubled in number at a joint. Very easy to split. Would you go 50x35mm?
Ryan Bazeley Posted May 17, 2021 Author Posted May 17, 2021 Hi, thanks for your comments. 25 x 50 battens are what’s specified by Kingspan so should be okay. I think?
SuperJohnG Posted July 30, 2021 Posted July 30, 2021 @Ryan Bazeley what did you use in the end? I'm just trying to get battens did you use rough sawn or c16?
