Printer1 Posted April 23, 2021 Posted April 23, 2021 Hi renewing lead flashing, taking down 2.2m, recommended length seems to be 1.5, will 2.2 be ok or 2 pieces.
nod Posted April 23, 2021 Posted April 23, 2021 1 hour ago, Printer1 said: Hi renewing lead flashing, taking down 2.2m, recommended length seems to be 1.5, will 2.2 be ok or 2 pieces. Yes that’s fine
Russell griffiths Posted April 23, 2021 Posted April 23, 2021 Fold up the 2.2 bit and pick it up, you might find a shorter piece easier to handle, unless there are two of you to support and guide it into position.
Kernow Posted May 2, 2021 Posted May 2, 2021 Rough rule to use, code 4 lead, maximum 1.5m lengths Code 5 lead, max 2m lengths 150mm overlap on joins
