Ben100 Posted April 14, 2021 Posted April 14, 2021 Hi all, I’ve purchased a shower arm, head, and valve from Victorian Plumbing, but I can’t work out how they fit together...? It seems they don’t provide the connections between them all. Will I need some kind of flexible connector? Here are the parts https://www.victorianplumbing.co.uk/arezzo-matt-black-concealed-individual-stop-tap-thermostatic-control-shower-valve and https://www.victorianplumbing.co.uk/arezzo-round-200mm-matt-black-fixed-shower-head-wall-mounted-arm
ProDave Posted April 14, 2021 Posted April 14, 2021 Standard plumbing fittings and rigid copper or something like Hep20 Here are mine, similar type of shower
Ben100 Posted April 14, 2021 Author Posted April 14, 2021 9 minutes ago, ProDave said: Standard plumbing fittings and rigid copper or something like Hep20 Here are mine, similar type of shower Ah, interesting. I see you’ve mounted the valve and shower to the sheathing instead of the joists. Good idea! How did you secure your shower arm? My arm says you’ve got to use a back nut, but the thread is only 14mm. How are you supposed to get the thread through tiles, plasterboard, back nut, and compression fitting on 14mm!? ?
markc Posted April 14, 2021 Posted April 14, 2021 The valves need to sit back from the surface, hence the boarding. and the arm screws into a bulkhead type fitting (not sure of the correct name for it)
Ben100 Posted April 14, 2021 Author Posted April 14, 2021 3 minutes ago, markc said: The valves need to sit back from the surface, hence the boarding. and the arm screws into a bulkhead type fitting (not sure of the correct name for it) Right. I was going to batten out to create the void, but your way is better!
