WWilts Posted March 21, 2021 Posted March 21, 2021 Attic height too low for habitable room, but interested in having storage space there without overburdening roof truss beams. Any suggestions?
joe90 Posted March 21, 2021 Posted March 21, 2021 I have done just that in our warm loft, used I beams fir rafters with 400mm insulation between, osb clad inside and sealed, foldable loft ladder into large loft with floor. 1
WWilts Posted March 21, 2021 Author Posted March 21, 2021 21 minutes ago, joe90 said: used I beams fir rafters Thanks. Did the roof truss supplier include the I Beam as part of the truss, or did you add I Beams between the roof trusses?
MortarThePoint Posted March 21, 2021 Posted March 21, 2021 May be cheaper to ask the truss designer to include a loading in the truss design. You could then use loft legs: https://www.wickes.co.uk/Loftleg-Raised-Floor-Loft-Legs---175mm-Pack-of-12/p/100412 1
epsilonGreedy Posted March 21, 2021 Posted March 21, 2021 3 hours ago, joe90 said: I have done just that in our warm loft, used I beams fir rafters with 400mm insulation between, osb clad inside and sealed, foldable loft ladder into large loft with floor. Interesting, I was hoping PIR sheets between the ceiling and attic floor boards would equal 250mm of regular loft insulation but was worried this could be a moisture trap and be a concern with insulated wires. Am I picturing the I beans correctly, do they sit inline and on top of the truss joists or are they laid across the truss direction? 1
joe90 Posted March 22, 2021 Posted March 22, 2021 8 hours ago, epsilonGreedy said: Interesting Depends if you want a warm loft or cold loft. Mine is warm (insulation under slates), My whole roof structure is made of I beams instead of rafters, the depth, 400mm, gives me 400mm for rockwall insulation. 1
