Hi all.
We are laying kingspan K103 insulation boards before putting out UFH pipe on top.
Normally if it’s a foil face board you tape up all the seams and joins. But the K103 that kingspan recommend is a paper faced board.  Is it best to leave it as it is or to still tape it up?
regards.
1200gauge, what’s that for ?
have you got a dpm under the insulation?
the membrane that goes on top is just very thin polythene it’s not a dpm
buy the thinnest clear polythene, then you can see your kingspan as you staple it, avoids trying to put a staple in a join and them pulling out.
As @ADLIan said what does it say on kingspan site.
I would try try to do two layers not one then you can stagger joins.
