Energy Statement
dabba
In the planning process for a self build bungalow (plus bedroom & bathroom in roof space) design all agreed,
I've been sent the draft conditions all straight forward apart from one  'details shall demonstrate a reduction in carbon emissions of a least 28% through the provision of renewable or low carbon technologies or through energy efficiency measures and at least a 19% reduction in dwelling emission rate compared to the Target Emission rate'
I think this is a new requirement for our area, and I'm struggling to find any formation how to address this condition, I would welcome some advice please.
relative to what? particularly if insulation/mvhr can be considered an energy efficiency measure
2 minutes ago, dabba said:
Thanks for reply, would this need to be done by a specialist?
Usually by an OCDEA (On Construction Domestic Assessor) who would also do the carbon emissions as part of the design SAP assessment
I come across these types of planning conditions on a regular basis and it is obvious that they are written by people who don't know what they are talking about. You actually have 2 slightly different conditions here, I normally deal with these as follows;
  • The 19% reduction in DER over the TER is simple and will probably mean using renewables/low energy (need to check with the planners what is included or allowable here!)
  • The 28% reduction is arrived at by removing all of the above renewables and comparing the DER/TER (this dwelling may fail the Regs but this is not an issue for the planning condition). Ask the question of the planners - doubt you'll get a sensible reply!
As above get an OCDEA on board asap to advise.
Ridiculous situation of local authority introducing these conditions and not having a clue what they are doing.
Sometimes there is a get out clause stating if the planning condition makes the scheme not economically viable the condition can be dropped. A scheme of 17 houses near me had a similar condition dropped when the developer made a simple statement to this effect but no figures or costings to back up this statement!
Has the local authority a 'sustainability officer' or similar you could ask.
Can I just check my understanding of this is correct?
  • The 19% reduction is saying that the SAP CO2 emissions must be at least 19% better than a building of the same shape and size built to building regulations minimum.
  • The 28% reduction is in practice saying that you must have a big enough PV system to offset 28% of the CO2 emissions of your final building.
@pdf27
The 19% reduction is saying that the SAP CO2 emissions must be at least 19% better than a building of the same shape and size built to the notional building specification in Appendix R of SAP2012 (page108). Can also be found in Part L1A.
IMHO The 28% is so undefined as to be impossible to quantify
Edited by A_L
Thanks for your replies, I must admit it came out of the blue, checked with planner and it definitely must stay as a condition, I was hoping to see earlier applications with this requirement to see what they had come up with but its that recent I can't find any.
