MikeSharp01 Posted March 18, 2021 Share Posted March 18, 2021 We have a few places where we need to get some cold bridges around windows dealt with and it looks to me like STYROFOAM™ will do it. It is XPS has a compressive strength of around 30T / m2, a good U value at 0.033, is very workable, and is not expensive if brought as sheets. Any opinions / thoughts / experience anyone? Link to comment Share on other sites More sharing options...
Tennentslager Posted March 18, 2021 Share Posted March 18, 2021 Does it burn? Link to comment Share on other sites More sharing options...
SteamyTea Posted March 18, 2021 Share Posted March 18, 2021 Have you thought about how you will bond it, and if there is any PVC nearby? Link to comment Share on other sites More sharing options...
MikeSharp01 Posted March 18, 2021 Author Share Posted March 18, 2021 Just now, SteamyTea said: PVC nearby No PVC nearby - mostly it will be clamped between / under wood to provide thermal breaks. I have used gorilla glue on XPS in the past, works OK. Link to comment Share on other sites More sharing options...
PeterW Posted March 18, 2021 Share Posted March 18, 2021 Why not use PIR..? Tissue faced one side would work. Link to comment Share on other sites More sharing options...
MikeSharp01 Posted March 18, 2021 Author Share Posted March 18, 2021 11 minutes ago, PeterW said: Why not use PIR Not sure I can cut it as neatly, XPS will cut on the hot wire, given the volume the U factor is not an issue. Link to comment Share on other sites More sharing options...
Bruno Posted March 25, 2021 Share Posted March 25, 2021 Insulation of windows with XPS boards is a common recommendation here. Especially the "box" above the window where the blinds roller work. These are direct connection to the outside in both cold and dirt ? I did that myself a few weeks ago, most of my neighbours already did it (or paid someone to do it for them) with very good results. I'm extremely happy with my results, especially after also finding a cover for the blinds "strap". Link to comment Share on other sites More sharing options...
