thomas Posted May 25, 2016 Share Posted May 25, 2016 Has anyone approached any of the big EWI/render manufactures from a self build point of view? The likes of Jub, Stro, Alumac etc There are some quite cheap systems on ebay, for example 1m2 of 150mm graphite eps with a complete render system for £16. So surly there must be some good deals from suppliers. Link to comment Share on other sites More sharing options...
ProDave Posted May 25, 2016 Share Posted May 25, 2016 £16 per metre sounds unbelievably cheap. I am paying more than that per square metre just for the labour to apply my render, so I can't see how anyone can do it including materials for that price. Link to comment Share on other sites More sharing options...
thomas Posted May 25, 2016 Author Share Posted May 25, 2016 (edited) It's this system Link here It's ceresit system which is well known, their thin coats have some good feedback from plasterers. I lied for 150mm grey or 200mm white it was 16.88/m2. You will be paying much more than £16 for labour this is material only. Edited August 30, 2016 by Nickfromwales Link inserted Link to comment Share on other sites More sharing options...
K78 Posted August 29, 2016 Share Posted August 29, 2016 (edited) I looked at EWI in depth. The cost of installation is extortionate in the uk. Probably because of government grants. I think a 300mm insulated cavity is a cheaper option. Even if it shouldn't be. Most of the fitters are very inexperienced and small mistakes can cause huge issues. The render systems also don't age well. Spots appear on light colours where the mechanical fixings are. EWI works better under cladding/rain screen IMO. Edited August 29, 2016 by K78 Link to comment Share on other sites More sharing options...
ProDave Posted August 30, 2016 Share Posted August 30, 2016 On 25 May 2016 at 21:54, thomas said: It's this systemhttp://www.ebay.co.uk/itm/182110766652 It's ceresit system which is well known, their thin coats have some good feedback from plasterers. I lied for 150mm grey or 200mm white it was 16.88/m2. You will be paying much more than £16 for labour this is material only. That's not what I used, but at £16 per square metre for everything including the insulation panels it does sound very cheap. Link to comment Share on other sites More sharing options...
