January 18, 20215 yr I've got an oak block worktop from worktops express. About 40mm thick. They advise a moisture barrier stuck to it's underside where you have a washing machine, oven or dishwasher. They talk vaguely about heat and moisture. Is a barrier needed above a fridge with a small freezer compartment? thanks
January 18, 20215 yr Nope - just things like dishwashers although a better method is to oil the underside too with Osmo Top Oil before the appliances are fitted as it stops moisture getting into the wood.
January 19, 20215 yr I am not sure oiling it once will provide a lifetime barrier. Metallised foils are better as they are impermeable and deflect heat away as well.
January 19, 20215 yr Most dishwashers come with a deflector plate which is to be nailed into wood/laminate worktops. Then tend to corrode with time so its better to use the metal foil and the deflector as belt and braces
January 19, 20215 yr 1 hour ago, ryder72 said: I am not sure oiling it once will provide a lifetime barrier. Metallised foils are better as they are impermeable and deflect heat away as well. Agree - I was suggesting oil plus the barrier rather than just oil (probably wasn’t clear)
