Grendel Posted January 18, 2021 Posted January 18, 2021 I've got an oak block worktop from worktops express. About 40mm thick. They advise a moisture barrier stuck to it's underside where you have a washing machine, oven or dishwasher. They talk vaguely about heat and moisture. Is a barrier needed above a fridge with a small freezer compartment? thanks
PeterW Posted January 18, 2021 Posted January 18, 2021 Nope - just things like dishwashers although a better method is to oil the underside too with Osmo Top Oil before the appliances are fitted as it stops moisture getting into the wood.
ryder72 Posted January 19, 2021 Posted January 19, 2021 I am not sure oiling it once will provide a lifetime barrier. Metallised foils are better as they are impermeable and deflect heat away as well.
dpmiller Posted January 19, 2021 Posted January 19, 2021 Miele lab machines come with the deflector in the install kit.
ryder72 Posted January 19, 2021 Posted January 19, 2021 Most dishwashers come with a deflector plate which is to be nailed into wood/laminate worktops. Then tend to corrode with time so its better to use the metal foil and the deflector as belt and braces
PeterW Posted January 19, 2021 Posted January 19, 2021 1 hour ago, ryder72 said: I am not sure oiling it once will provide a lifetime barrier. Metallised foils are better as they are impermeable and deflect heat away as well. Agree - I was suggesting oil plus the barrier rather than just oil (probably wasn’t clear) 1
