I’m toying with the idea of adding a steam generator to our en-suite shower. I would need to replace the door and side panel with a suitable floor to ceiling ‘glass wall’ to make it an enclosure. Then it’s just a matter of fitting the plumbing and wiring for the steam generator kit.
Has anyone done this themselves? Any advice?
You have to use GRP or steam proof panels for the walls as anything else will have issues. These guys do some nice stuff - saw them at one of the shows.
Made several hundred of them.
Normal GRP will fail fairly quickly.
What sort of steam generator are you using, will you need softened water?
Edited by SteamyTea
I'm planning on putting a steam room in, must admit I haven't devoted too much time on the how but was planning on tiling the entire enclosure. Not sure what the craic is with steam proof wall panels - another thing I need to look into i suppose?‍♂️
They need to withstand temperatures of 55°C and 100% RH for prolonged periods of time.
Similar numbers are used when 'rapid aging' paints and adhesives.
And you will need some sort of extraction in the bath room, but not in the actual cabinet.
Edited by SteamyTea
I think La3222 just answered the question for me.
Rog. There will be an MVHR extract in the bathroom, where steam room is located. I see what you mean ref the working conditions for GRP, but if you tile rather than GRP then the problem is solved? (I am assuming nothing needs to go behind tiles other than tanking perhaps in order to seal all the moisture in the steam room?)
As long as the adhesive can take the temperature and RH, and you still need to put a lid on it.
Acrylic can usually take the temperature, why they use it for bath tubs.  Just use cast acrylic sheet, not extruded.
Why not just fit a sauna.  Easy wooden box with an electrical heater, not messing about with water (other than cleaning down).
Make sure the unit can handle all the water that will pass though it.
Edited by SteamyTea
Was going to tile the ceiling too.
I am. The 'bathroom' has a shower/steam room one side, sauna other, bath in middle.
Probably a bit excessive to have one, let alone both but what the hell, I'm only building one and I know they will get used a lot.
Not something I'd thought about tbh. Going to have to look at the potential implications of this to make sure there are no potential clangers!!
