Triassic Posted December 18, 2020 Share Posted December 18, 2020 I've finally got my Willis powered under floor heating working. But!! The earth leakage device on the split fuse board trips randomly. I switch the pump and Willis heater on and it will happily work for 10 to 20 minutes then trips for no obvious reason. I’ve double checked all the wiring and swapped the earth leakage device. Has anyone experienced similar, what should I be checking/replacing next? Link to comment Share on other sites More sharing options...
ProDave Posted December 18, 2020 Share Posted December 18, 2020 You need to do an insulation resistance check with a megger, most likely the immersion heater element is faulty. such faults often only show when the heater gets hot. Link to comment Share on other sites More sharing options...
Triassic Posted December 18, 2020 Author Share Posted December 18, 2020 Are the elements easy to change? Link to comment Share on other sites More sharing options...
dpmiller Posted December 18, 2020 Share Posted December 18, 2020 generally the modern willis is a soldered-up unit, it's rare to see one that has a seperate shell and element. Link to comment Share on other sites More sharing options...
Triassic Posted December 19, 2020 Author Share Posted December 19, 2020 17 hours ago, dpmiller said: generally the modern willis is a soldered-up unit, it's rare to see one that has a seperate shell and element. Yes they are! So no repair possible. Having checked the insulation resistance of the pump and the Willis I’ve concluded that the pump I may be at fault. Just off to get a new one. Link to comment Share on other sites More sharing options...
Triassic Posted January 1, 2021 Author Share Posted January 1, 2021 (edited) Having done some tests I had an hunch it was the pump at fault, it was second hand! A new pump fitted and everything is now running a dream. Edited January 1, 2021 by Triassic Link to comment Share on other sites More sharing options...
