Olf Posted December 16, 2020 Posted December 16, 2020 'The 50*50SHS 2.5mm thick S275 steel should be fixed to the existing concrete sub wall below with a 6mm S275 steel base plate and 2 no. M10 bolts.' says structural engineer report. Surely that will make a cold bridge - should I be concerned at all, considering relatively small cross section of the post? Is there any way (non-compressible pad?) used to avoid such thermal bridging?
TonyT Posted December 16, 2020 Posted December 16, 2020 https://www.farrat.com/wp-content/uploads/2020/09/DS-FTB-Farrat-TBF-20a.pdf
Russell griffiths Posted December 16, 2020 Posted December 16, 2020 What is that holding u, as it looks smaller than anything I’ve ever used in house construction, apart from a lightweight carport.
Olf Posted December 16, 2020 Author Posted December 16, 2020 @TonyT - big thanks, 'Structural Thermal Break' is what i need to shop around for. 1 hour ago, Russell griffiths said: What is that holding 127*76 RSJ supporting a half of the first floor (marked red). Currently there is 50x50 steel box profile at 0.37m from the central wall (believed to be a temporary support, left hidden inside the wall) and 90x90 wooden post at 1.52m from central wall. To accomodate the wardrobe I need to move the wooden post and SE calcs showed (I trust) that single 50x50 on the side of the wardrobe is enough.
