44 minutes ago, MrTrevithick said:
I don’t know is the straight answer, I just use it for the internet but I suppose if your phone can use the net for calls then yes?
Yes my phone can but SWMBO's can't so I need something that boosts providers voice data....
Or change her phone to your provider, it does not cost anthing.
18 hours ago, pocster said:
purpose fitted faraday cage
Why out of interest? Is this a purpose designed mesh cage in cast concrete walls like in some HMG buildings I've worked in? ?
Have you also got a tinfoil hat for when you go outside?
That’s not the issue . My phone can do calls over Wi-Fi hers can’t . Also I’d like to give a ‘good user experience’ when people visit I.e they can make calls whilst underground
Do I recall on here a member saying they bought a cheap booster and that the wall PSU went up in flames? I might have read it on another forum.
Right.
The live streaming of your orgies.  Seems reasonable.
9 minutes ago, SteamyTea said:
Right.
You'll  be wanting a 4Orgy booster then.
  • 5 months later...
I use a 17dbi dish router from Mikrotik to get my internet service from the 3 Network even though I'm technically not in coverage.
https://mikrotik.com/product/lhg_lte_kit
You need to pole mount it and line it up, but the signal you get is vastly superior to anything you'd get on an omnidirectional phone antenna.
If you're a non techy you may need a bit of help getting it running :)
