Russell griffiths Posted January 20, 2017 Posted January 20, 2017 Confused as normal, so doing some research as normal and all I keep reading about is breathable outer layers so moisture can escape outwards, makes sense to me. So why am I watching lots of install vids on products where they are taping the joints on the exterior racking sheeting boards? Most of the vids are American so I am careful to consider the climate difference between the two countries, it's no good watching them in Texas as compared with sunny Cirencester. But I also see them applying a stick on rain screen house wraps that are all produced by European companies. I like the idea of having a complete skin over the roofs and walls, but how does it all breath? I intend having a full MVHR system will it breath to the inside or have I got myself all muddled up again. Cheers russ.
gravelld Posted January 20, 2017 Posted January 20, 2017 Is this basically a difference between air tight and vapour tight style question? If so: http://www.ecohome.net/guide/difference-between-air-barriers-vapour-barriers 1
Crofter Posted January 20, 2017 Posted January 20, 2017 Sounds like it. You want to keep the wind from getting into your insulated shell and carrying away heat. The gap between a couple of sheets of OSB might not look like much but a strong wind will fairly whistle through that- I know because I have this issue at the moment myself on a few places.
Russell griffiths Posted January 20, 2017 Author Posted January 20, 2017 2 hours ago, gravelld said: Is this basically a difference between air tight and vapour tight style question? If so: http://www.ecohome.net/guide/difference-between-air-barriers-vapour-barriers Thanks for that I will have a good read tonight. ?
