Conor Posted October 26, 2020 Posted October 26, 2020 We're backfilling the basement in week or so - 12mm drainage stone against the face. We have the tanking layer stuck to the outer ICF face and an additional 50mm of EPS on top of that. Do I need a traditional drainage nboard against the EPS like you would for a tanking membrane? Or will the EPS be tough enough to be directly backfilled with stone? Tanking guys are recommending it but builder doesn't think it's needed. I'm worried about stones being forced between joins in the EPS panels.
ToughButterCup Posted October 26, 2020 Posted October 26, 2020 46 minutes ago, Conor said: ... Or will the EPS be tough enough to be directly backfilled with stone? ... If my experience is anything to go by, I think so. No stones got jammed in ours. Stones of a certain size 'stick' to it (you can brush them off later) , but thats all.
Alexphd1 Posted October 26, 2020 Posted October 26, 2020 Cant help on your question but what tanking did you use?
Adam2 Posted October 26, 2020 Posted October 26, 2020 My intention is membrane, double drain then EPS sheets. Having the double drain I thought was pretty standard.
Conor Posted October 27, 2020 Author Posted October 27, 2020 10 hours ago, Alexphd1 said: Cant help on your question but what tanking did you use? Koster https://shopwearesdg.com/koster-ksk-sy-15
Conor Posted October 28, 2020 Author Posted October 28, 2020 (edited) Spoke to the tanking company rep - said EPS as a protection for the tanking is satisfactory and will approve the warranty even without the cavity drain layer. Will be a very careful backfilling job! Edited October 28, 2020 by Conor
Adam2 Posted October 28, 2020 Posted October 28, 2020 7 hours ago, Conor said: Spoke to the tanking company rep - said EPS as a protection for the tanking is satisfactory and will approve the warranty even without the cavity drain layer. Will be a very careful backfilling job! Would be interested to know who you found for the warranty - is it a full warranty meaning consequential damages or limited to the value of the waterproofing products? I found it v hard to get full warranty for an underground EPS build. Re the double drain - I managed to find a relatively good value supplier of this (the type without the membrane) so thought no harm and maybe some benefit
Conor Posted October 29, 2020 Author Posted October 29, 2020 (edited) 13 hours ago, Adam2 said: Would be interested to know who you found for the warranty - is it a full warranty meaning consequential damages or limited to the value of the waterproofing products? I found it v hard to get full warranty for an underground EPS build. Re the double drain - I managed to find a relatively good value supplier of this (the type without the membrane) so thought no harm and maybe some benefit No idea. All I know is builder is required to provide structural and water ingress warranties as per the contract. 10year defects I think. I was only speaking to the rep as he was on site overseeing the tanking and okayed the design. Also found cheap drain sheets from drainage superstore, but didn't order them as not required and wouldn't be here on time before backfilling. Edited October 29, 2020 by Conor
Adam2 Posted October 29, 2020 Posted October 29, 2020 OK sounds good if your builder is providing this, I think some industry waterproofing schemes are linked to insurance cos to back-up a builder's own insurance which is great. If doing this stuff yourself then you can get a bit stuck as I found warranty companies aren't that interested in below-ground aspects with ICF and product suppliers don't tend to offer a comprehensive warranty - Sika stopped this a while back unfortunately. Yes - think that's where I got mine double drain from. I figured I'd have belt , braces and anything else.
