I have costs in from a few timber frame company’s, trying to work out how this compares to building out of brick and block. The timber frame quotes I have are for an insulated structure roof trusses and erection (no sniggering) I am working out how much it would cost to get to the same stage in blocks and bricks and need to know what else I need to cost for?
The list I have so far is as follows
240 m2 of inner wall + lintels
145 m2 of internal wall + lintels
10 no 7m x35d fink trusses
22no  12.5m x35d attic trusses
1 no 12m steel
10m cut roof @400 centres
Insulation
Sand + cement
What else needs to go on the list? I can work out prices from the web for materials if I know what’s needed
We are building a 270m2 t shape bungalow 240m2 living 30m2 garage.
Currently we are 50/50 ,can see the benefits in both systems and it might just come down to cost. if block and brick works out significantly cheaper I can live without the very quick build time .
I built tradition and have been doing the costings for our second
I’ve looked long and hard at TF
Both build types I’m very familiar with
If I use TF It will cost me around 25% more
Thanks Nod , i must admit i have been told that here is not much difference in price but some of the frame prices are eye watering .
@SteamyTeaI intended to have a site meeting at the start and issue the team with a clean as you go policy and a guide to good housekeeping in the work place . ?
I rewrote the words to The Laughing Policeman once.
Good luck with that.
