For my new (self) build house my builder is quoting what works out to be about £100 per sqm for approx 45sqm of slabbed paving.  Quote includes the slabs - 600x600 concrete slabs dyed dark grey as requested which cost £6 each.  The job would be done properly to a high standard.
Does this sound about right ?
Ouch !!! I’ll come and do it for £95... @Nickfromwales can labour for me ..!
Assuming this is onto a 150mm sub base that is onto a scraped site, it should be around £15/m for the sub base and then £10/m for sand and cement at 50mm to bed the slabs. Your slabs are £17/m so £20/m to lay and point you should be around the £60/m all in at most.
14 minutes ago, Declan52 said:
£93 but you need to tell me quick as NI is in lockdown from Fri 6pm so need somewhere to have a nice cold pint.
I'll fly some across the border with my new 'alcho-drone' ??️
Cheers for the breakdown so effectively they’re charging £60 per sq m labour.  I shall decline.
