After finishing my boys attic 'conversion' I now need to fine tune which detectors go where.
I need
1) for attic room
2) for back bedroom ( above kitchen )
3) landing
4) hall ( current battery one goes off when I cook steaks )
5) kitchen ( heat obviously )
My main concern upstairs is technology catching fire. PC / tv / consoles etc on standby through the day ( 4 kids so don't even say to put everything off during the day, never going to be a realistic option ), with same downstairs but more about appliances there.
Location 4 is the tricky one, but advice as to which is better, where, and hopefully why would be gratefully received.
Thanks all.
Edit to add : there are two bedrooms under the attic room, should I go crazy and cover those rooms too, or will the landing detector suffice?
You can't go wrong with Aico. With that many, possibly more I'd also fit a test/locate button to pinpoint which one in a hurry. Don't forget C02 up there if required.
I just followed the Aico advice so optical in the "common areas" and as I'm cheap I went for the 140 series not the 160 or the multi sensor.
Nothing wrong with the 140 series, as long as they are RC model,
As above , don't forget the CO detector,
