NOT turning UFH on before tiling
gc100
Hi,
My anhydrite based flow screed has been down for since 22 of May and is about 50mm so should be fully dry now (its also had a constant breeze flowing). Due to various schedules I cannot get the UFH commissioned until towards the end of Oct and we want to start putting tiles down well before.
Reading online its seems its alway recommended to do a round of heating  (and cooling) of the floor before installing however given my timelines this isn't really possible.
I'm now planning to use Ditra decoupling matting to held alleviate any heating cracks.
Has anyone done this or am I just asking for a lot of trouble?
Doing that cycle is referred to as a “thermal shock” of the slab. I wouldn’t be worried about that. The fact it’s Anhydrite is the worry. Has it been mechanically abraded after curing? There will be a scum layer that will stop anything sticking to the screed that needs to be dealt with, as nothing, and I mean nothing, will stick to it. Ditra, tile adhesive, primer, nowt.
I’ve been on jobs where 80+m2 of floor tiles are able to be lifted up with just the grout holding them together.
Ask questions, get answers ;)
Hi Nick,
Yes we mechanically abraded it all . Is the purpose of the thermal shock it make any would-be-cracks appear? Or is it something else?
I didnt take a chance with ours - it had a good heat shock to get all the movement out of the way.  1 wee crack appeared in the slab which the tiler bridged over with some sort of membrane.   If your tiler says to do it then I would - will he guarantee the job incl materials if it goes wrong?
The builder is doing it, and no he doesn't guarantee  (i'm paying day rate).
Your builder is tiling?
Good stuff. Just switch the heating on for 48 hours and run it at around 30oC. What will be will be. ?
1 hour ago, gc100 said:
Hi,
I would always run the heating before tiling
As a business I’ve tiled plenty Usually commercial that simply can’t be heated up before tiling
I did a favor job for The MD of a company that gives us lots of work
Bio boiler wasn’t commissioned
S&C screed had been down two weeks 200m2 needed to be down and grouted in two days
No time to F##k about with Ditra
His words 1200 Porcelain slats
Four years on still fine
He just said if it has to come up after Christmas So be it
But I have to be in for Christmas
Make sure you Leave a 10 mil gap around the edge and plenty of expansion joints and you will be ok
