Carrerahill Posted September 7, 2020 Posted September 7, 2020 Our flush valve is leaking, apart from the leak the annoying result is the fill valve pulsing on and off every blinking 2-3 minutes to refill the lost water. Looks like the seal down at the bottom is just letting a trickle of water past constantly. I have identified our flush valve as a Siamp Skipper 45 Dual Flush and to save any hassle I was just going to buy another the same. The valve itself seals to the cistern with a big o-ring, but what about the seal from the cistern to the pan? Are they all the same size? The whole point of getting the same valve is so that I can do the job without needing to strip it down, go and find someone who stocks the bits drive about, come home, fit it and generally spend 3 hours doing something that should take 30mins. So can anyone confirm the anatomy of a toilet?
dpmiller Posted September 7, 2020 Posted September 7, 2020 generally the gubbins of the unit bayonets into a bottom mounting boss so possibly no need to remove the cistern. 1 1
Carrerahill Posted September 7, 2020 Author Posted September 7, 2020 3 minutes ago, dpmiller said: generally the gubbins of the unit bayonets into a bottom mounting boss so possibly no need to remove the cistern. Hmmm - yes I can see that, there are some lugs in there. I might have a look later. If I can do it all from up top that would be good. Maybe I can even find a replacement seal for the valve rather than total replacement!
Carrerahill Posted September 7, 2020 Author Posted September 7, 2020 19 minutes ago, dpmiller said: generally the gubbins of the unit bayonets into a bottom mounting boss so possibly no need to remove the cistern. Bang on - I now have the flush body sitting in the basin, looks like the seal is hard, I can get a new one. 1
Temp Posted September 7, 2020 Posted September 7, 2020 4 hours ago, Carrerahill said: Maybe I can even find a replacement seal for the valve rather than total replacement! +1 Google is your friend.. https://www.ebay.co.uk/p/1105422802?iid=174235519784&chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=174235519784&targetid=938486031820&device=c&mktype=pla&googleloc=9044886&poi=&campaignid=10204071591&mkgroupid=104953044434&rlsatarget=aud-629407026665:pla-938486031820&abcId=1145987&merchantid=113581527&gclid=CjwKCAjwtNf6BRAwEiwAkt6UQoF47Xb2HrB4pIPOQ_BK-Oob3deo_Fvt1ZlZR5lSe3y99yyfprppwBoCCvEQAvD_BwE https://www.amazon.co.uk/Siamp-34233209-Sealing-Washer-Skipper/dp/B00JKN14JO https://www.plumbinbits.co.uk/siamp-storm-skipper-flush-valve-seal-34233209
