Internet Know How Posted September 5, 2020 Posted September 5, 2020 Hey, I am looking at starting a build early new year and the 200sqm footprint will start below ground. - Looking for someone in the merseyside / north west area who can dig out - Ground is 100% sand, so will be disposing of this for free with a local firm. - I will need someone to then lay the slab and walls below ground, and then form the ground floor level ready for the bricklayers to come in Can anyone recommend a decent firm? Have you done a basement dig previously and how was such a job priced / what did it cost to just get to ground level Thanks Chris
Rmawdsley Posted September 6, 2020 Posted September 6, 2020 Hi Chris, Your price will vary on the complexity of the design. A simple square will be cheaper than something that has more corners/angles. Insurance companies require you to have 2 water proof systems in place eg. Voltex along with caltite cementaid. So depending on how labour intensive the systems specified are and the cost of the materials, that can add a degree of variability to the cost. Do you have any drawings of the proposed basement yet? Kind regards, Robert
Internet Know How Posted September 16, 2020 Author Posted September 16, 2020 On 06/09/2020 at 16:04, Rmawdsley said: Hi Chris, Your price will vary on the complexity of the design. A simple square will be cheaper than something that has more corners/angles. Insurance companies require you to have 2 water proof systems in place eg. Voltex along with caltite cementaid. So depending on how labour intensive the systems specified are and the cost of the materials, that can add a degree of variability to the cost. Do you have any drawings of the proposed basement yet? Kind regards, Robert Expand Hi Robert, Thanks for your reply. This is the proposed shape, and if only it was a true rectangle it would help. I was reading the other day that under the warranty cover, I would be looking at following a certain type of waterproofing system. I noted type A,B,C with type C being the preferred method. This is 62 linear meters, sat on a 230sqm slab actually. Walls will be 2.8m high. Overall there will be 140m3 of concrete.
Mr Punter Posted September 16, 2020 Posted September 16, 2020 It looks like the plan was done with an etch a sketch (not a simple rectangle, but well worth seeing what @Rmawdsley has to say.
