CRees Posted January 6, 2017 Share Posted January 6, 2017 Hi all, I am after some advice on the cost of a two storey extension, measuring approximately 25m2 floor area with blockwork cavity walls, standard windows and slate roof. I am looking at purchasing a property in West Wales which would benefit from an extension. Thanks in advance. Link to comment Share on other sites More sharing options...
MikeSharp01 Posted January 6, 2017 Share Posted January 6, 2017 You probably need to budget around £25K @£1000 per square meter but could go up or down. UP if you have difficult ground, employ an architect, Structural Engineer and include additional kitchen / bathroom areas. DOWN if you have easy ground, can design it yourself, can do a lot of the work yourself (WAY DOWN) and its just an open space with only electric points and simple lighting. Your actual location will also be a factor. Link to comment Share on other sites More sharing options...
CRees Posted January 6, 2017 Author Share Posted January 6, 2017 Hi Mike, many thanks for your advice. Link to comment Share on other sites More sharing options...
Mr Punter Posted January 7, 2017 Share Posted January 7, 2017 £30k Link to comment Share on other sites More sharing options...
zoothorn Posted May 17, 2019 Share Posted May 17, 2019 On 06/01/2017 at 18:26, CRees said: Hi all, I am after some advice on the cost of a two storey extension, measuring approximately 25m2 floor area with blockwork cavity walls, standard windows and slate roof. I am looking at purchasing a property in West Wales which would benefit from an extension. Thanks in advance. @CRees Hi how did your extension go/ did you buy the property? Id be very interested to know, as Im in same boat/ west wales in need of similar sized extension I'm waiting on a quote for. Link to comment Share on other sites More sharing options...
TT-Smyth Posted May 22, 2019 Share Posted May 22, 2019 I would say anywhere between £1,200 to £2,500 per m2 depending on design specs. Link to comment Share on other sites More sharing options...
