This walls always been a pain .
It’s been supposedly fixed before ( cracks in External render filled )
This is the downstairs lounge wall . Bathroom directly above . Bathroom internal wall seems fine . No obvious leak in bathroom. No water marks on ceiling in lounge . Assume not a roof issue as half way down .  Nothing obvious outside , even checked in the rain .
Edited by pocster
What is the wall construction?  If is is cavity, there should be a cavity tray / DPC above the window lintel sloping to the outside leaf with weep holes either end to let water drain out.
Presume it’s cavity
There’s a lip above the window external directing water away . I’ll grab a photo later
35 minutes ago, Mr Punter said:
Is this in your dungeon place or the dosshouse Luxury HMO?
Lol the ‘basic’ non luxury hmo . All my houses leak
Well spotted.  Get your ladder and up you go.  You may find one of those ladder stand off brackets will make it easier if you need to unclip a section.
If you were to lift a tile or two you may find the underlying roofing felt that should direct into the gutter has perished/split/sunk. Eaves protectors might help.
Even a blocked downpipe/gutter can contribute to something like this.
I don’t do heights . So up builder goes .... ????
Standing on the edge of a big hole playing with a scaffold winch is still working at height.....possibly even more dangerous as you don't have to erect anything or climb for it to be a hazard.
G i r l
