scottishjohn Posted July 28, 2020 Posted July 28, 2020 any magic cures for roots in drains .other than the obvious way of digging them up
Mr Punter Posted July 28, 2020 Posted July 28, 2020 If there is not much you can get rid the culprit trees / shrubs and cut the roots out internally. You can re-line sections, but probably simpler to replace the offending run. 1
PeterW Posted July 28, 2020 Posted July 28, 2020 Copper sulphate into the drains works over time but also screws up the tank at the other end ... 1
Declan52 Posted July 28, 2020 Posted July 28, 2020 The experts can clear them. They use a rotating head that attaches to a power hose. It spins round cutting the roots. It's only a temp fix as they will continue to grow back though. 1
scottishjohn Posted July 28, 2020 Author Posted July 28, 2020 (edited) that about what i thought -guys problem is it is next doors garden my sewer line goes through there to join to a common man hole and the roots are coming from a tree in their garden . that will be a nice conversation and who pays the bill and remakes the garden? my view is drains were there before they planted things --so they have caused the problem the fail attachment to cut the roots --i would worry that it would also damage the plastic drain maybe in between way -cut down the tree -kill it -attempt cut roots and wait and see what happens in a year or so Edited July 28, 2020 by scottishjohn
