We are having Siberian Larch cladding over most of our timber frame house and we want a corner post detail similar to this :-
Ideally, the corner post needs to be flush with the cladding, or protrude slightly. The battens we are using are 47mm and the cladding is 21mm thick, so really we need a corner post around 70mm square. I've been looking everywhere (including the supplier of the cladding) for a 70-75mm Siberian Larch corner post but haven't been able to find anything (most seem to expect a 20mm batten so have a 44mm x 44mm corner post).
Anybody know of any suppliers who might be able to do a 75mm square Siberian Larch post?
Edited by Andrew
Take the battens out over each other or use a double batten then get the joiner to notch out a 44x44 by 20mm on the inside edge with a table saw. Will leave you an L Angle that will cover the corner batten then butt the cladding up to it.
Thanks @PeterW and @Russell griffiths, spoke to the chippies today and they are going to pack it out so we can use the 44mm corner posts.
I did find someone who could supply 95mm x 95mm Siberian larch, which were sold as fence posts ?
