metal posts for gates - how big?
CC45
Hi all,
just planning ahead for August / Sept - I'd like to get around to erecting some gates on what hopefully will be our new access.  We are thinking of 6ft wooden gates within a metal frame, sort of like:
We would like to use metal posts - with no brick surround.  These black metal posts will match some railings that we will also put down.  The gates will be between 5ft and 6 ft high and 6ft wide each.  How big a post do we need?  Does anyone have experience of this?
6" x 6" post?  8" x 8"?  5mm thick metal?  Do we fill the post with something to help strenghten them?  How far in the ground do they need to be? (6'6" out of the ground - 3' in it?) Would it benefit from a square foot welded to the bottom?
Any advice gratefully received.
CC
I would use 100mm square box minimum, 4 or 5 mm wall, galvanised and concreted in at in least 1m. A 6' gate is not that big a load  but you might prefer the aesthetic of 150 or 200 box.
A foot on the box is optional , you could plonk it on a pad stone.
One idea: go to your local agricultural merchant and have a look at their metal  gateposts.
It may not be an intuitive answer, but they should have posts designed for gates that are up to 12ft wide and up to 7 bar, and so will  be very robust.
When I have these they have usually been approx 8 ft 6 in long, and I have used them around 1/3 in the ground. They seem to come in 3"-5" diameters.
You may wish to put some type of cosmetic larger post round it.
Ferdinand
